Ana içeriğe geç
Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Battery: adım 1, 1 resimden 1.
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 2, 2 resimden 1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 2, 2 resimden 2.
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: adım 3, 3 resimden 1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: adım 3, 3 resimden 2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: adım 3, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
  4. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 4, 3 resimden 1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 4, 3 resimden 2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 4, 3 resimden 3.
    • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
    • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
    • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
  5. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 5, 1 resimden 1.
    • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
  6. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 6, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
  7. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 7, 1 resimden 1.
    • Using a spudger, lift up and remove the plastic cover piece from the back cover.
    • Plastic cover may fall off without prying.
  8. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 8, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
  9. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: adım 9, 1 resimden 1.
    • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
    • Metal cover may fall off without prying.
  10. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: adım 10, 2 resimden 1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: adım 10, 2 resimden 2.
    • Push on the back panel buttons from the frontside of the back cover.
    • There might be some adhesives holding the back panel buttons to the cover. Extra force may be necessary.
Sonuç
Kingsley East
462 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-9, Williams Fall 2016 Baylor, Team 5-9, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G9
3 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 648
