Ana içeriğe geç
Panasonic Lumix DMC-GF2 Front Cover Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-GF2 Front Cover Replacement, Battery: adım 1, 1 resimden 1.
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Front Cover Replacement: adım 2, 2 resimden 1. Panasonic Lumix DMC-GF2 Front Cover Replacement: adım 2, 2 resimden 2.
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: adım 3, 3 resimden 1. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: adım 3, 3 resimden 2. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: adım 3, 3 resimden 3.
    • Using a Philips #00 screwdriver, remove six 2.69 mm screws located on the two short sides and on the bottom of the camera.
    • To loosen a screw, turn the screwdriver to the left. To tighten a screw, turn the screwdriver to the right.
  4. Panasonic Lumix DMC-GF2 Front Cover Replacement: adım 4, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove four black 2.69 mm screws from the front of the camera.
  5. Panasonic Lumix DMC-GF2 Front Cover Replacement: adım 5, 1 resimden 1.
    • Using your hand, gently lift up the front cover and separate it from the camera.
Sonuç
Nicole Gerlach
218 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 5-9, Williams Fall 2016 Baylor, Team 5-9, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G9
3 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,039
