Ana içeriğe geç
Panasonic Lumix DMC-GX85 Display Screen Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-GX85 Display Screen Replacement, Display Screen: adım 1, 1 resimden 1.
    • Turn the camera so that the shutter side faces the ground and the lens faces you.
  2. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 2, 3 resimden 1. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 2, 3 resimden 2. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 2, 3 resimden 3.
    • Remove the two 2mm Phillips #0 screws on the bottom of the screen.
  3. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 3, 2 resimden 1. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 3, 2 resimden 2.
    • Swivel the screen away from the camera body so it is facing the ground.
  4. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 4, 3 resimden 1. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 4, 3 resimden 2. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 4, 3 resimden 3.
    • Remove the two 6.0mm Phillips #0 screws on the back of the screen.
  5. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 5, 3 resimden 1. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 5, 3 resimden 2. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 5, 3 resimden 3.
    • Orient the camera so the lens is facing the ground.
    • Using the gap created behind the screen at the bottom, stick the iFixit opening tool inside the gap and gently open the gap.
    • Work the tool evenly around the back of the display to evenly separate the two pieces. Once the back cover is separated enough, remove it by hand.
  6. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 6, 3 resimden 1. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 6, 3 resimden 2. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 6, 3 resimden 3.
    • Be sure to use extreme caution when handling the ribbon cable to ensure the wiring within it stays intact.
    • Place the camera so that the lens is facing the ground.
    • Using the iFixit opening tool, pry the black connector open and remove the ribbon.
  7. Panasonic Lumix DMC-GX85 Display Screen Replacement: adım 7, 1 resimden 1.
    • Gently remove the screen from the camera body.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thank you very much!
jptrinkster - Yanıt
Hi ! Thanks for the tutorial, any idea if this would be the same repair with a DC-GX9 ? The screen size seems to match
Clem - Yanıt
Thanks for the guide. From step 7, how do I further dismantle the screen. I bought a replacement screen, but its in a simpler form
Kamil Zidane - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 89
Her zaman: 3,885
