Giriş
Do you need to replace the screen of your Panasonic Lumix DMC-GX85? Follow this guide to replace it! All you need is a Phillips head screwdriver and a plastic pry tool. As always, be careful when working on sensitive electronics, as screens are very fragile.
Neye ihtiyacın var
Turn the camera so that the shutter side faces the ground and the lens faces you.
Orient the camera so the lens is facing the ground.
Using the gap created behind the screen at the bottom, stick the iFixit opening tool inside the gap and gently open the gap.
Work the tool evenly around the back of the display to evenly separate the two pieces. Once the back cover is separated enough, remove it by hand.
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thank you very much!
Thanks for the guide. From step 7, how do I further dismantle the screen. I bought a replacement screen, but its in a simpler form
