Ana içeriğe geç
Panasonic Lumix DMC-GX85 Main PCB Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-GX85 Main PCB Replacement, Rear Cover: adım 1, 3 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement, Rear Cover: adım 1, 3 resimden 2. Panasonic Lumix DMC-GX85 Main PCB Replacement, Rear Cover: adım 1, 3 resimden 3.
    • Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
  2. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 2, 3 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 2, 3 resimden 2. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 2, 3 resimden 3.
    • Using a spudger, gently lift the forward end of the shoe spring to disengage its locking mechanism.
    • While holding the forward end of the shoe spring up, push from its lifted end to remove the shoe spring.
  3. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 3, 2 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 3, 2 resimden 2.
    • Remove the two 6.0mm silver Phillips #0 screws closest to the display screen.
    • Do not remove the two forward-most silver screws.
  4. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 4, 2 resimden 2.
    • Turn the camera so the side with the jack cover is facing you.
    • Near the camera's top end, remove the 4.0mm black Phillips #0 screw on the bottom in this orientation.
    • Open the jack cover and remove the 4.0mm black Phillips #0 screw inside.
  5. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 5, 2 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 5, 2 resimden 2.
    • Flip the camera upside down so the bottom of the camera is facing you.
    • Remove the two center 2.5mm black Phillips #0 screws.
    • Remove the outer 4.5mm black Phillips #0 screw.
  6. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 6, 3 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 6, 3 resimden 2. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 6, 3 resimden 3.
    • Turn the camera so the display screen is facing you.
    • Rotate the top of the screen away from the camera body to access and remove the 4.5mm black Phillips #0 screw.
    • Remove the rear camera cover by gently pulling from the top side.
    • When removing the rear cover, pull apart slowly to prevent damaging the ribbon cable connecting the display screen and the Sub PCB.
  7. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 7, 3 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 7, 3 resimden 2. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 7, 3 resimden 3.
    • Turn the camera so the lens is facing down with the rear cover pulled back.
    • Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
    • Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
    • Do not bend the ribbon cable excessively and take care not to damage the ribbon cable.
  8. Panasonic Lumix DMC-GX85 Main PCB Replacement, Main PCB: adım 8, 2 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement, Main PCB: adım 8, 2 resimden 2.
    • Remove the three 3.5mm silver Phillips #0 screws mounting the main PCB to the camera frame.
  9. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 9, 3 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 9, 3 resimden 2. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 9, 3 resimden 3.
    • Disconnect the eight ribbon cables from the main PCB by pulling up on the black locking tabs with an iFixit opening tool.
    • Pull the ribbon cables from the connectors.
  10. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 10, 3 resimden 1. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 10, 3 resimden 2. Panasonic Lumix DMC-GX85 Main PCB Replacement: adım 10, 3 resimden 3.
    • Gently lift the motherboard away from the camera body.
    • When removing the main PCB, take care not to lose the battery earth plate.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Good day. How do I get the board both of the, the one on the right and one on d left
Tobas - Yanıt
Where i can find this replacement ? DMC-GX85 Main PCB Replacement
vissente tapia cuevas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 58
Her zaman: 2,754
