Giriş
This is the circuit board that the AV chord attaches to for transferring images.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
Carefully remove the function switch cover. This unit snaps on and off.
Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
Use the spudger to unclip the top ribbon cable from the circuit board.
2 farklı kişi bu kılavuzu tamamladı.
