Ana içeriğe geç
Panasonic Lumix DMC-TZ5 button board Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-TZ5 button board Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the battery and memory card from the device.
  2. Panasonic Lumix DMC-TZ5 button board Replacement: adım 2, 1 resimden 1.
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Panasonic Lumix DMC-TZ5 button board Replacement: adım 3, 1 resimden 1.
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Panasonic Lumix DMC-TZ5 button board Replacement: adım 4, 1 resimden 1.
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Panasonic Lumix DMC-TZ5 button board Replacement: adım 5, 1 resimden 1.
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Panasonic Lumix DMC-TZ5 button board Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-TZ5 button board Replacement: adım 6, 2 resimden 2.
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Panasonic Lumix DMC-TZ5 button board Replacement: adım 7, 1 resimden 1.
    • Remove the back casing from the camera.
  8. Panasonic Lumix DMC-TZ5 button board Replacement, button board: adım 8, 2 resimden 1. Panasonic Lumix DMC-TZ5 button board Replacement, button board: adım 8, 2 resimden 2.
    • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
    • Carefully remove the function switch cover. This unit snaps on and off.
  9. Panasonic Lumix DMC-TZ5 button board Replacement: adım 9, 1 resimden 1.
    • Carefully unsnap the front logic board from the rear logic board using a spudger.
  10. Panasonic Lumix DMC-TZ5 button board Replacement: adım 10, 2 resimden 1. Panasonic Lumix DMC-TZ5 button board Replacement: adım 10, 2 resimden 2.
    • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  11. Panasonic Lumix DMC-TZ5 button board Replacement: adım 11, 3 resimden 1. Panasonic Lumix DMC-TZ5 button board Replacement: adım 11, 3 resimden 2. Panasonic Lumix DMC-TZ5 button board Replacement: adım 11, 3 resimden 3.
    • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
    • This leaves you with the logic board and the top connection panel separate and free from the camera
Sonuç
Ben Canfield
409 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-21, Regan Fall 2010 Cal Poly, Team 9-21, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G21
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 5,596
