Ana içeriğe geç
Panasonic Lumix DMC-ZS25 Lens Replacement
Neye ihtiyacın var
    1. Panasonic Lumix DMC-ZS25  Lens  Replacement, Camera lens: adım 1, 3 resimden 1. Panasonic Lumix DMC-ZS25  Lens  Replacement, Camera lens: adım 1, 3 resimden 2. Panasonic Lumix DMC-ZS25  Lens  Replacement, Camera lens: adım 1, 3 resimden 3.
      • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
      • Remove the two 2.60 mm screws located next to the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 2, 1 resimden 1.
      • Use the iFixit opening tool to open the outer cover of your device.
      • The easiest place to open your device is from the HDMI port.
      • Gently open it to avoid breaking the cover.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 3, 3 resimden 1. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 3, 3 resimden 2. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 3, 3 resimden 3.
      • Use a spudger to detach the ribbon cable.
      • Be careful when using the spudger, as it can cause damage to the ribbon.
      • After releasing the screen cable, use the iFixit opening tool to lift the button board.
      • Once you hear a "click" sound, you have successfully opened the buttons board.
      FixBot'a Sor
      Yorum Ekle
    4. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 4, 2 resimden 2.
      • Remove the screen using the iFixit opening tool.
      FixBot'a Sor
      Yorum Ekle
    5. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 5, 2 resimden 1. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 5, 2 resimden 2.
      • Open the two 4.20 mm screws to remove the inner cover located beneath the screen.
      • Use the iFixit opening tool to assist in safely removing the inner cover.
      FixBot'a Sor
      Yorum Ekle
    6. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 6, 2 resimden 2.
      • Separate the device into two pieces as shown.
      FixBot'a Sor
      Yorum Ekle
    7. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 7, 3 resimden 1. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 7, 3 resimden 2. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 7, 3 resimden 3.
      • Remove the side cover using the iFixit opening tool.
      • Exercise caution when you remove the front cover as damage to the device can occur.
      FixBot'a Sor
      Yorum Ekle
    8. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 8, 3 resimden 1. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 8, 3 resimden 2. Panasonic Lumix DMC-ZS25  Lens  Replacement: adım 8, 3 resimden 3.
      • Use the spudger to unlock the screen cables from the circuit bored. Carefully, lift up the black clip up to release the cables.
      • Use your hands to remove the lens.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Abbas Khan
482 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G5
3 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 18
Son 30 gün: 54
Her zaman: 3,067
