Ana içeriğe geç
Panasonic Lumix DMC-ZS25 Power Button Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: adım 1, 3 resimden 1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: adım 1, 3 resimden 2. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: adım 1, 3 resimden 3.
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Open it gently to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 3, 2 resimden 1. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 3, 2 resimden 2.
    • Use a spudger to detach the ribbon cable.
    • Be careful when you use the spudger because you do not want to break the the ribbon.
  4. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 4, 3 resimden 1. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 4, 3 resimden 2. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 4, 3 resimden 3.
    • Remove the button board using the plastic opening tool.
    • Remove the screen. Lift the screen from the right hand side.
    • After your hear a "click" sound, you have successfully opened the screen.
  5. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 5, 2 resimden 1. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 5, 2 resimden 2.
    • Remove the two black screws that are located beneath the screen.
    • Lift the metal cover using the plastic opening tool.
  6. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 6, 2 resimden 2.
    • Use the plastic opener to remove the side covers.
  7. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 7, 2 resimden 1. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 7, 2 resimden 2.
    • After removing the side covers, you will be able to take away the front cover with your hands.
    • Do not apply too much pressure on the outer cover of your device to avoid damage.
  8. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 8, 1 resimden 1.
    • To release the top cover of the camera, you need to open the 3.70 mm screw shown in the picture.
  9. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 9, 1 resimden 1.
    • Remove the top cover using the plastic opening tool.
  10. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 10, 3 resimden 1. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 10, 3 resimden 2. Panasonic Lumix DMC-ZS25  Power Button Replacement: adım 10, 3 resimden 3.
    • After removing the top cover of the camera, you will be able to easily remove the power button with your hand.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Abbas Khan
482 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G5
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 570
