Ana içeriğe geç
Panasonic Lumix DMC-ZS25 Screen Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: adım 1, 3 resimden 1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: adım 1, 3 resimden 2. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Screen Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to open the outer cover of your device from the HDMI port.
    • Open it carefully to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Screen Replacement: adım 3, 3 resimden 1. Panasonic Lumix DMC-ZS25  Screen Replacement: adım 3, 3 resimden 2. Panasonic Lumix DMC-ZS25  Screen Replacement: adım 3, 3 resimden 3.
    • Use a spudger to carefully detach the ribbon cable without breaking it.
  4. Panasonic Lumix DMC-ZS25  Screen Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to lift and remove the buttons board as shown.
  5. Panasonic Lumix DMC-ZS25  Screen Replacement: adım 5, 2 resimden 1. Panasonic Lumix DMC-ZS25  Screen Replacement: adım 5, 2 resimden 2.
    • Carefully lift the screen using the plastic opening tool as shown.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Abbas Khan
482 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G5
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
nasorenga - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 4,406
