Ana içeriğe geç
Panasonic Lumix DMC-ZS25 Flash Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: adım 1, 2 resimden 1. Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: adım 1, 2 resimden 2.
    • Using a small screwdriver, remove the four 3.4mm screws from the right and left sides of your Panasonic Lumix Camera.
  2. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 2, 1 resimden 1.
    • Using a small screwdriver, remove the two 2.6mm screws located next to the battery, on the outer casing.
  3. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 3, 1 resimden 1.
    • Using the plastic opening tool, open the outer cover of your device.
    • The easiest way to open your device is by placing the tool in the HDMI port.
  4. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 4, 3 resimden 1. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 4, 3 resimden 2. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 4, 3 resimden 3.
    • Using the spudger, pull upward on the screen cable to release it.
  5. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 5, 1 resimden 1.
    • Using the plastic opening tool, lift the button board until it clicks.
  6. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, lift the screen until it clicks.
  7. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 7, 1 resimden 1.
    • Using a small screwdriver, remove the two 4.2mm screws located on the corner of the inner cover, under the screen.
  8. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 8, 1 resimden 1.
    • Using the plastic opening tool, remove the inner cover.
  9. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 9, 2 resimden 1. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 9, 2 resimden 2.
    • Using your hands or the opening tool, separate the device into two pieces, as shown.
  10. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 10, 2 resimden 1. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 10, 2 resimden 2.
    • Using the spudger, remove the black side cover.
  11. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 11, 1 resimden 1.
    • Using your hands, remove the front cover.
  12. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 12, 3 resimden 1. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 12, 3 resimden 2. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 12, 3 resimden 3.
    • Using the spudger, unlock the screen cables from the circuit board.
    • Lift up the black clip to release the cables.
  13. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 13, 1 resimden 1.
    • Using your hands, remove the lens.
  14. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 14, 1 resimden 1.
    • Using the plastic opening tool, pull up on the edge of the circuit board until it clicks.
    • Remove the board.
  15. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 15, 1 resimden 1.
    • Using a small screwdriver, remove the 3.7 mm screw near the green chip inside the camera, as shown. This will release the top of the camera.
  16. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 16, 3 resimden 1. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 16, 3 resimden 2. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 16, 3 resimden 3.
    • Using the opening tool, pull up on the edge of the top cover to unlock it.
  17. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 17, 2 resimden 1. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 17, 2 resimden 2.
    • Using the opening tool, remove the top board.
  18. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 18, 2 resimden 1. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 18, 2 resimden 2.
    • Place the tip of the spudger at the edge of the top board, and work around three sides to loosen it.
    • Using the opening tool, lift up the top board. Now you will be able to safely remove the flash.
  19. Panasonic Lumix DMC-ZS25 Flash Replacement: adım 20, 1 resimden 1.
    • Remove the old flash, and put in the replacement.
Sonuç
Abbas Khan
482 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G5
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 409
