Ana içeriğe geç
Panasonic Lumix DMC-ZS25 Speaker Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS25 Speaker Replacement, Speaker: adım 1, 3 resimden 1. Panasonic Lumix DMC-ZS25 Speaker Replacement, Speaker: adım 1, 3 resimden 2. Panasonic Lumix DMC-ZS25 Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Remove the four 3.4 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.6 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to lift off the rear cover of your device. Go gently to avoid breaking anything.
    • The easiest place to open your device is from the HDMI port.
    • Gently does it.
  3. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 3, 3 resimden 1. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 3, 3 resimden 2. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 3, 3 resimden 3.
    • Use a spudger to lift the LCD ribbon cable locking bar by angling it up, then withdraw the ribbon.
    • Take care not to break it.
    • Use the plastic opening tool at the bottom right hand side of the button board to lift it up and out.
    • The buttons board comes out with a "click" as it snaps out of a connector below.
  4. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 4, 2 resimden 2.
    • The LCD is retained by a clip on the left hand side, which you can release with a plastic opening too.
    • Lift the LCD from the left hand side, disengaging it at the right hand side from two small tabs.
  5. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 5, 2 resimden 1. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the two 4.2 mm screws in order to remove the inner cover located beneath the screen.
    • Having removed the screws, use the plastic opening tool to lift off the inner cover, releasing it from clips on the top and bottom edges.
  6. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the side covers using the plastic opening tool.
  7. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 7, 2 resimden 1. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 7, 2 resimden 2.
    • After removing the side covers, you will be able to pull off the front cover.
    • Be careful when you pull the front cover to avoid breaking anything.
  8. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 8, 1 resimden 1.
    • To remove the top cover, you need to remove a 3.7 mm screw as shown.
  9. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 9, 3 resimden 1. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 9, 3 resimden 2. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 9, 3 resimden 3.
    • Release the top cover by lifting several tabs with the plastic opening tool. Go gently to avoid breaking them.
  10. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 10, 3 resimden 1. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 10, 3 resimden 2. Panasonic Lumix DMC-ZS25 Speaker Replacement: adım 10, 3 resimden 3.
    • With the top cover removed the speaker can be very easily removed or replaced.
Sonuç
Abdulaziz Alotaibi
176 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G5
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
In step 5, comparing it with the similar DMC-TZ35 I rather think there should be 3 screws, not 2. A 3rd hole can be seen at the bottom.
Philip Le Riche - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 782
