Ana içeriğe geç
Panasonic Lumix DMC-ZS3 Battery Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS3 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the small, hinged door on the bottom of the camera.
  2. Panasonic Lumix DMC-ZS3 Battery Replacement: adım 2, 1 resimden 1.
    • Using your fingernail or a spudger, push the small, grey switch on the hinged door from the left (locked) to the right (unlocked).
    • The hinged door should swing open after unlocking.
  3. Panasonic Lumix DMC-ZS3 Battery Replacement: adım 3, 1 resimden 1.
    • Using your fingernail or a spudger, push down on the small, grey tab holding the battery in place.
    • This should release the battery.
  4. Panasonic Lumix DMC-ZS3 Battery Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-ZS3 Battery Replacement: adım 4, 2 resimden 2.
    • Pull the battery out of the camera.
    • The battery should slide out easily.
Sonuç
Ekip
Cal Poly, Team 13-60, Johann Spring 2013 Cal Poly, Team 13-60, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G60
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 22
Her zaman: 1,252
