Ana içeriğe geç
Panasonic Lumix DMC-ZS35 Back Casing Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: adım 1, 3 resimden 1. Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: adım 1, 3 resimden 2. Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: adım 1, 3 resimden 3.
    • Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
  2. Panasonic Lumix DMC-ZS35 Back Casing Replacement: adım 2, 2 resimden 1. Panasonic Lumix DMC-ZS35 Back Casing Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to carefully separate the back casing from the main body of the camera. It's advised to run along the entire "seam" of the casing and the camera with the tool to ensure full separation.
  3. Panasonic Lumix DMC-ZS35 Back Casing Replacement: adım 3, 1 resimden 1.
    • Gently pry apart the back casing from the body of the camera. It's recommended to apply as minimal force as is necessary to prevent unintended damage to the camera or the casing.
Sonuç
John Schug
97 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 üyesi
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 172
