Ana içeriğe geç
Panasonic Lumix DMC-ZS40 Camera Lens Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Battery: adım 1, 2 resimden 1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Battery: adım 1, 2 resimden 2.
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 2, 1 resimden 1.
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 3, 2 resimden 1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 3, 2 resimden 2.
    • Remove battery from camera.
  4. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, LCD Screen: adım 4, 3 resimden 1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, LCD Screen: adım 4, 3 resimden 2. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, LCD Screen: adım 4, 3 resimden 3.
    • Unscrew the five 3mm screws located around the sides of the camera using a PH000 bit or Phillips 000 Screwdriver.
  5. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 5, 2 resimden 1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 5, 2 resimden 2.
    • Pry off the back casing of the camera and place the camera face down.
  6. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 6, 1 resimden 1.
    • Flip the right hand side control dial circuit board up.
  7. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 7, 3 resimden 1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 7, 3 resimden 2. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Turn the LCD screen over to the side exposing the connection to the motherboard.
    • Remove the display data cable connecting the LCD screen to the motherboard. Using tweezers, pry up the black retaining flap then gently pull the display data cable free.
    • Be careful when handling any display data cables in the camera as they are prone to tearing.
    • To close for reassembly, slide the display data cable back into the ZIF connector and close the retaining flap.
  8. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Motherboard: adım 8, 1 resimden 1.
    Satın Al
    • Disconnect the control dial from the motherboard. Locate the ZIF connector for the control dial. Use tweezers or screwdrivers to lift up on the retaining flap to remove the ribbon cable.
    • The connector ribbons are prone to tearing so use care during removal.
  9. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 9, 1 resimden 1.
    • Pry the HDMI cover off the side of the camera.
    • No tools are required for this step.
  10. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 10, 3 resimden 1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 10, 3 resimden 2. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 10, 3 resimden 3.
    • Remove these four 4mm on the top of the plate cover and the 3mm screw on the side of the camera using a PH000 bit head. Once the screws are removed, the plate cover should lift right up.
    • Keep track of the different screw lengths and do not mix them up.
  11. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 11, 2 resimden 1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 11, 2 resimden 2.
    • Pry the black cover shielding the ZIF connectors off with your hand.
  12. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 12, 2 resimden 1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: adım 12, 2 resimden 2.
    • Disconnect these 6 ribbon cables from the motherboard. Use tweezers or a screw driver to lift up on the retaining flaps for each ZIF connector.
  13. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Camera Lens: adım 13, 2 resimden 1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Camera Lens: adım 13, 2 resimden 2.
    • Once the corresponding ribbon cables have been detached, the lens assembly can be lifted right up.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dean Favetta
340 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 20-3, Remmell Spring 2017 USF Tampa, Team 20-3, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G3
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
My Lumix is a bit older and so did not follow exactly. But this was helpful enough to allow me to work through the lens issue. In doing some reading, often the lens doesn't need replacing, just a good cleaning or even to reset it in the housing which worked for me. One thing I would say is refrain from taking the plastic clamps off. They are hard to get off and usually snap due to how brittle they get. Instead, leave in place and be careful with the cable.
David Blitt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 1,899
