Ana içeriğe geç
Panasonic Lumix DMC-ZS6 LCD Assembly Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement, LCD Assembly: adım 1, 1 resimden 1.
    • Remove the battery and SD card.
  2. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: adım 2, 3 resimden 1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: adım 2, 3 resimden 2. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: adım 2, 3 resimden 3.
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: adım 3, 1 resimden 1.
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: adım 4, 2 resimden 2.
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: adım 5, 1 resimden 1.
    • Use the tip of the spudger to flip up the metal tabs.
    • Lift the LCD panel out of place carefully.
Sonuç
Derrick Thompson
1.035 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S2-G5, Johnson Spring 2018 Baylor, Team S2-G5, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 195
