Ana içeriğe geç
Panasonic Lumix DMC-ZS6 SD Card Reader Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement, SD Card Reader: adım 1, 1 resimden 1.
    • Remove the battery and the SD card.
  2. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 2, 3 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 2, 3 resimden 2. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 2, 3 resimden 3.
    • Unscrew the bottom two 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws on the right with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws on the left with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 3, 1 resimden 1.
    • Carefully separate the back of the camera from the main body.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 4, 2 resimden 2.
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 5, 3 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 5, 3 resimden 2. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 5, 3 resimden 3.
    • Unscrew the bottom 1.0 mm screw with a Phillips #000 screwdriver.
  6. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 6, 1 resimden 1.
    • Separate the front of the camera from the main body.
  7. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 7, 2 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 7, 2 resimden 2.
    • Use the tip of the spudger to disengage the plastic tab.
    • Carefully lift the selector switch away from the motherboard.
  8. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 8, 2 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 8, 2 resimden 2.
    • Unscrew the three silver 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the spudger to disengage the metal tab.
    • Carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 9, 1 resimden 1.
    • Insert the tip of the spudger into the center hole of the tripod mount.
    • Apply force in the direction facing away from the button.
    • Carefully lift the tripod mount out of the camera body.
  10. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 10, 2 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 10, 2 resimden 2.
    • Use the spudger to flip up the brown tab on the motherboard and carefully unseat the ribbon cable.
    • Insert the tip of the spudger into the hole on the daughterboard.
    • Apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 11, 3 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 11, 3 resimden 2. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 11, 3 resimden 3.
    • Use the spudger to flip up the two tabs on the motherboard and carefully unseat the ribbon cables.
    • Use the Phillips #000 screwdriver to remove the three 1.0 mm silver screws.
    • Carefully lift the lens assembly out of the camera.
  12. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 12, 3 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 12, 3 resimden 2. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 12, 3 resimden 3.
    • Use the tip of the spudger to disengage the tab on the back of the camera.
    • Use the tip of the spudger to disengage the two tabs on the front of the camera.
    • Carefully lift the top assembly out of place.
  13. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 13, 2 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 13, 2 resimden 2.
    • Use the spudger to disengage the two tabs.
    • Carefully lift the flash assembly out of place.
  14. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 14, 3 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 14, 3 resimden 2. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 14, 3 resimden 3.
    • Use the tip of the spudger to flip up the tab to unseat the ribbon cable.
    • Unscrew the two silver 1.0 mm screws with a Phillips #000.
    • Use the tip of the spudger to disengage the two plastic tabs, and carefully lift the motherboard out of place.
  15. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 15, 2 resimden 1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 15, 2 resimden 2.
    • Unscrew the one silver 1.0 mm screw with a Phillips #000 screwdriver.
    • Use to tip of the spudger to disengage the plastic tab, then carefully lift the plastic shield out of place.
  16. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: adım 16, 1 resimden 1.
    • Carefully lift the SD card reader assembly out of place.
Sonuç
Derrick Thompson
1.035 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S2-G5, Johnson Spring 2018 Baylor, Team S2-G5, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,253
