Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This step by step guide will help you replace any damaged or malfunctioning SD card readers from your camera correctly.
Neye ihtiyacın var
Use the tip of the 2.0 mm flathead screwdriver to flip up the tab on the ribbon cable, then carefully unseat the ribbon cable
Unscrew the two silver 1.0 mm screws with a Phillips #000
Use the tip of the 2.0 mm flathead screwdriver to disengage the two plastic tabs, and carefully lift the motherboard out of place
