Ana içeriğe geç
Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: adım 1, 3 resimden 1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: adım 1, 3 resimden 2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: adım 1, 3 resimden 3.
    • Remove the side panels by unscrewing the Phillips head screws on both sides of the camera.
  2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: adım 2, 3 resimden 1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: adım 2, 3 resimden 2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: adım 2, 3 resimden 3.
    • Remove the back panel by unscrewing the two Phillips head screws on the bottom of the camera towards the back.
    • Lift the back panel from the camera and set it aside.
  3. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: adım 3, 3 resimden 1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: adım 3, 3 resimden 2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: adım 3, 3 resimden 3.
    • Unscrew the Phillips head screw shown in the picture to remove the front panel.
    • Remove the front panel to expose the bracket at the bottom of the camera.
  4. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: adım 4, 3 resimden 1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: adım 4, 3 resimden 2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Pry the right side of the bracket up to allow you to grab the bracket with tweezers.
    • Grab the bracket with tweezers and slide it toward the battery door to remove it from the frame of the camera.
Sonuç
Trevor Meyers
356 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 310
