Ana içeriğe geç
Panasonic Lumix DMC-ZS8 Screen Panel Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS8 Screen Panel Replacement, Screen Panel: adım 1, 3 resimden 1. Panasonic Lumix DMC-ZS8 Screen Panel Replacement, Screen Panel: adım 1, 3 resimden 2. Panasonic Lumix DMC-ZS8 Screen Panel Replacement, Screen Panel: adım 1, 3 resimden 3.
    • Remove all four screws from the side panels.
  2. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 2, 3 resimden 1. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 2, 3 resimden 2. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 2, 3 resimden 3.
    • Remove the two screws from the bottom of the back panel.
    • Remove the back panel as shown in the second and third pictures.
  3. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 3, 3 resimden 1. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 3, 3 resimden 2. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 3, 3 resimden 3.
    • Remove the screen from the mounting bracket.
    • Slide the wiring from the board connection.
  4. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 4, 3 resimden 1. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 4, 3 resimden 2. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 4, 3 resimden 3.
    • Reconnect the new screen wiring into the motherboard as shown in the picture. Replace the new screen into the mounting bracket.
  5. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 5, 3 resimden 1. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 5, 3 resimden 2. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 5, 3 resimden 3.
    • Replace the front panel and install the screws on the bottom side of the camera.
  6. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 6, 3 resimden 1. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 6, 3 resimden 2. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 6, 3 resimden 3.
    • Replace the side panels and replace the four screws to secure the side panels.
  7. Panasonic Lumix DMC-ZS8 Screen Panel Replacement: adım 7, 1 resimden 1.
    • This is what your newly replaced screen should look like.
Sonuç
Now you have a new screen for your Panasonic DMC-ZS8.
6 farklı kişi bu kılavuzu tamamladı.
Trevor Meyers
356 İtibar
2 adet Kılavuz yazıldı
Ekip
Bir Yorum
Where do I buy the new screen in the UK? I have been searching online, but not found one for my DMC-TZ70
Bernard Spence - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 2,075
