Ana içeriğe geç
Panasonic Lumix ZS50 Battery Replacement
Neye ihtiyacın var
  1. Panasonic Lumix ZS50 Battery Replacement, Battery: adım 1, 2 resimden 1. Panasonic Lumix ZS50 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Battery Replacement: adım 2, 2 resimden 1. Panasonic Lumix ZS50 Battery Replacement: adım 2, 2 resimden 2.
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Battery Replacement: adım 3, 1 resimden 1.
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Battery Replacement: adım 4, 1 resimden 1.
    • The battery should now be released; you may now remove the battery from the camera body.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cameron Voos
32 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 8-5, Whitney Spring 2017 Baylor, Team 8-5, Whitney Spring 2017 üyesi
BU-WHITNEY-S17S8G5
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Repair guide is very clear and well-done
BayleeVersteeg - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 513
