Ana içeriğe geç
Panasonic Lumix ZS50 Flash Assembly Replacement
Neye ihtiyacın var
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: adım 1, 2 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: adım 1, 2 resimden 2.
      • Turn the camera off and identify the battery door located on the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 2, 2 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 2, 2 resimden 2.
      • Slide the "open" latch to the left: the battery door should spring open.
      • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 3, 1 resimden 1.
      • To release the battery, slide the white release lever next to the SD card slot.
      • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
      FixBot'a Sor
      Yorum Ekle
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 4, 1 resimden 1.
      • The battery should now be released; you may now remove the battery from the camera body.
      FixBot'a Sor
      Yorum Ekle
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: adım 5, 3 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: adım 5, 3 resimden 2. Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: adım 5, 3 resimden 3.
      • Orient the camera so the bottom is facing up and the battery door is on the right side.
      • Remove four black screws from the bottom of the camera.
      • Remove two black screws from the right side of the camera.
      • Remove one black screw from the left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 6, 2 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 6, 2 resimden 2.
      • Remove the casing from the camera by hand or using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 7, 2 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 7, 2 resimden 2.
      • Use a spudger to lift up and tug off the green button board.
      • Be careful to not damage the attached ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 8, 3 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 8, 3 resimden 2. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 8, 3 resimden 3.
      • Remove the screen using the plastic opening tool, prying from the top.
      • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
      FixBot'a Sor
      Yorum Ekle
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: adım 9, 3 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: adım 9, 3 resimden 2. Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: adım 9, 3 resimden 3.
      • Remove the three screws from the center of the copper plate.
      • Remove the four screws from the outer edges of the copper plate.
      • Use a plastic or metal spudger to pry the copper plate out of place.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 10, 2 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 10, 2 resimden 2.
      • Remove the casing from the circuitboard by hand.
      • Remove the HDMI port casing by hand.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 11, 3 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 11, 3 resimden 2. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 11, 3 resimden 3.
      • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
      • Disconnect the circuitboard by hand.
      • There will be one orange ribbon cable attached to the top that can now be removed.
      FixBot'a Sor
      Yorum Ekle
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 12, 3 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 12, 3 resimden 2. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 12, 3 resimden 3.
      • Remove the seven screws surrounding the lens assembly.
      • Move all ribbon cables out of your way while unscrewing.
      • Remove the three springs surrounding the lens.
      • Apply pressure on the front of the lens to push the lens out.
      FixBot'a Sor
      Yorum Ekle
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: adım 13, 3 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: adım 13, 3 resimden 2. Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: adım 13, 3 resimden 3.
      • Remove the one screw holding the camera and the flash component together.
      • Gently pull the flash component out of the camera body.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 14, 3 resimden 1. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 14, 3 resimden 2. Panasonic Lumix ZS50 Flash Assembly Replacement: adım 14, 3 resimden 3.
      • Separate the top camera casing from the flash component by unscrewing the three surrounding screws.
      • Remove the flash assembly, including the circuit board, by detaching it and the ribbon cables from the casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bridget Lathrop
158 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-5, Whitney Spring 2017 Baylor, Team 8-5, Whitney Spring 2017 üyesi
BU-WHITNEY-S17S8G5
3 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
Step 7: Does not mention the HDMI port door. Make sure you account for it
BayleeVersteeg - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 65
Her zaman: 989
