Ana içeriğe geç
Panasonic Lumx DMC-ZS19 LCD Screen Replacement
Neye ihtiyacın var
  1. Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Locate the pair (2) of screws on each side of the camera and remove them. Then locate the pair (2) of screws on the bottom of the camera, located on each side of the tripod screw-in area, and remove them.
  2. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Using the plastic prying tool, remove the cover of the camera that is on the same side as your LCD screen. This cover should come off relatively easily, and will expose the motherboard that the screen is connected to.
  3. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Disconnect the motherboard that the LCD screen is connected to from the main motherboard.
  4. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Using your hand, follow the two data-strips that connect the LCD screen to the motherboard and unclip them. Once the data-strips are unclipped, remove them from the motherboard and the screen will be free.
Sonuç
Patrick Thoennissen
494 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-1, Meier Fall 2015 USF Tampa, Team 14-1, Meier Fall 2015 üyesi
USFT-MEIER-F15S14G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 297
