Ana içeriğe geç
Giriş
How to fix squeaky water flow
Parçalar
Hiçbir parça belirtilmedi.
  1. Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull Shake it a litlle so the tube can get out here.
    • Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull
    • Shake it a litlle so the tube can get out here.
    • This clear plastic is fragile,
    • be careful with it or the clipse may break.
  2. More pictures, look. you can clean it with citric acid. you can clean it with citric acid.
    • More pictures, look.
    • you can clean it with citric acid.
  3. Android Tamir Setleri
    A new screen or battery is one kit away.
    Hemen Alışveriş Yapın
  4. How to open. First remove two PH2 screws left and right. PULL the complete display. Shake it a little because the flap of the ice-crusher could be frosted. Now pull it downwards. Now turn around and you see the plastic from the lever.
    • How to open. First remove two PH2 screws left and right.
    • PULL the complete display. Shake it a little because the flap of the ice-crusher could be frosted.
    • Now pull it downwards. Now turn around and you see the plastic from the lever.
  5. This is the backside: The quadratic black rubber part is a motorized flap of the ice-crusher, be careful with it, there are fragile springs, dont loose them.
    • This is the backside: The quadratic black rubber part is a motorized flap of the ice-crusher, be careful with it, there are fragile springs, dont loose them.
    • Now spray some SILICONE_SPRAY on the moving parts, i made some red circles for it. Just a little bit, also on the springs.
    • TRY, move it, now the noise should gone, whiole moving it.
    • Thats it, reassemble it, be careful with the notches and clipse.
    • done. :)
Sonuç
easy
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Schwarzstein dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Schwarzstein
2.361 İtibar
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 4
Son 30 Gün: 15
Her zaman: 677
