Giriş
This guide shows how to remove the side panel containing the LCD viewing screen and speakers to gain access to other parts of the camera.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
Rotate the camcorder so that the tape compartment is facing you.
Remove the single 4.5mm black screw above the hook for the hand strap.
Undoing the strap on one end may help.
Rotate the camcorder so that the lens is facing you.
Remove the single 4.5mm black screw from the front panel.
Remove the indicated 4.5mm screws from the LCD side of the camera.
Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
Using two tools may be useful, if difficult.
Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
Remove the panel from the camcorder.
Bir başkası bu kılavuzu tamamladı.
