Ana içeriğe geç
Panasonic RQ-2102 Holding Handle Replacement
Neye ihtiyacın var
  1. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: adım 1, 3 resimden 1. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: adım 1, 3 resimden 2. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: adım 1, 3 resimden 3.
    • Remove the three M5-0.8 x 12 mm Phillips #0 screws from the back of the device body.
    • There are two more screws inside the battery compartment. Remove those as well.
    • Cautiously remove the back of the device body. Be sure not to damage the cord that connects the two sides.
    • All of the screws are the same size.
  2. Panasonic RQ-2102 Holding Handle Replacement: adım 2, 2 resimden 1. Panasonic RQ-2102 Holding Handle Replacement: adım 2, 2 resimden 2.
    • Carefully remove the handle. Make sure the handle catches on each side are intact.
    • Replace the old handle with the new handle.
    • Remember, if the handle catches are broken, the device must be replaced.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 556
