Ana içeriğe geç
Panasonic SA-HT810V DVD Drive Replacement
Neye ihtiyacın var
  1. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: adım 1, 3 resimden 1. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: adım 1, 3 resimden 2. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: adım 1, 3 resimden 3.
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove the screw that is on the right side of the panel facing you.
    • Remove all screws with a phillips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Panasonic SA-HT810V DVD Drive Replacement: adım 2, 2 resimden 1. Panasonic SA-HT810V DVD Drive Replacement: adım 2, 2 resimden 2.
    • Rotate the device so that the back faces you.
    • Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
    FixBot'a Sor
    Yorum Ekle
  3. Panasonic SA-HT810V DVD Drive Replacement: adım 3, 1 resimden 1.
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
    FixBot'a Sor
    Yorum Ekle
  4. Panasonic SA-HT810V DVD Drive Replacement: adım 4, 3 resimden 1. Panasonic SA-HT810V DVD Drive Replacement: adım 4, 3 resimden 2. Panasonic SA-HT810V DVD Drive Replacement: adım 4, 3 resimden 3.
    • Pull up the two tabs on top
    • Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you.
    • Depress the four tabs on the bottom of the device with a flat head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Panasonic SA-HT810V DVD Drive Replacement: adım 5, 1 resimden 1.
    • Carefully pull off the front panel of the device.
    • The front is attached to the device with cables so be careful when removing.
    FixBot'a Sor
    Yorum Ekle
  6. Panasonic SA-HT810V DVD Drive Replacement: adım 6, 2 resimden 1. Panasonic SA-HT810V DVD Drive Replacement: adım 6, 2 resimden 2.
    • Remove the four screws around the DVD drive with a phillips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Panasonic SA-HT810V DVD Drive Replacement: adım 7, 1 resimden 1.
    • The DVD player is attached to the power supply.
    • Remove the wire attaching it by firmly pulling on the wire until it releases.
    FixBot'a Sor
    Yorum Ekle
  8. Panasonic SA-HT810V DVD Drive Replacement: adım 8, 1 resimden 1.
    • Flip the DVD drive so that the bottom is facing you.
    • Pull on the blue ribbon cable until it releases.
    • To place the new DVD drive in just follow these steps in reverse.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan Cheadle
161 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G5
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 44
Her zaman: 1,976
