Ana içeriğe geç
Panasonic SA-PM17 CD Tray Cover Replacement
Neye ihtiyacın var
  1. Panasonic SA-PM17 CD Tray Cover Replacement, Disassembling front of the Panasonic SA-PM17: adım 1, 2 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement, Disassembling front of the Panasonic SA-PM17: adım 1, 2 resimden 2.
    • Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
    FixBot'a Sor
  2. Panasonic SA-PM17 CD Tray Cover Replacement: adım 2, 1 resimden 1.
    • Remove these seven 11.5 mm screws and place aside.
    FixBot'a Sor
  3. Panasonic SA-PM17 CD Tray Cover Replacement: adım 3, 1 resimden 1.
    • Lift the right side off of the device and place aside.
    • Repeat for left side.
    FixBot'a Sor
  4. Panasonic SA-PM17 CD Tray Cover Replacement: adım 4, 1 resimden 1.
    • Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
    • Do not pull the top too far as there are wires attached to it.
    FixBot'a Sor
  5. Panasonic SA-PM17 CD Tray Cover Replacement: adım 5, 2 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 5, 2 resimden 2.
    • Gently lift up on the indicated tabs to disengage them from the hooks holding them in place.
    FixBot'a Sor
  6. Panasonic SA-PM17 CD Tray Cover Replacement: adım 6, 1 resimden 1.
    • Lift up the top while firmly sliding it towards the back of the device.
    • Do not lift the top up too high as there are cords that need to be detached before the top can be removed.
    • The next step is a zoom-in of the indicated area.
    FixBot'a Sor
  7. Panasonic SA-PM17 CD Tray Cover Replacement: adım 7, 1 resimden 1.
    • Using forceps or fingers, remove the small black wire indicated.
    • Grip the wire near its base and pull gently but firmly until it pops out of the slot.
    FixBot'a Sor
  8. Panasonic SA-PM17 CD Tray Cover Replacement: adım 8, 3 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 8, 3 resimden 2. Panasonic SA-PM17 CD Tray Cover Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • This step deals with the indicated area of the device.
    • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
    • Gently pull on the cord near its base until it comes free of the restraint.
    FixBot'a Sor
  9. Panasonic SA-PM17 CD Tray Cover Replacement: adım 9, 3 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 9, 3 resimden 2. Panasonic SA-PM17 CD Tray Cover Replacement: adım 9, 3 resimden 3.
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it comes free of the attachment.
    • The top section of the device should now be free of the body. Place it aside in a safe place.
    FixBot'a Sor
  10. Panasonic SA-PM17 CD Tray Cover Replacement: adım 10, 3 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 10, 3 resimden 2. Panasonic SA-PM17 CD Tray Cover Replacement: adım 10, 3 resimden 3.
    • This step deals with the indicated portion of the the device.
    • Lift the indicated tabs out until they look like the final picture.
    • Gently pull on the cord until it comes free of its restraint.
    FixBot'a Sor
  11. Panasonic SA-PM17 CD Tray Cover Replacement: adım 11, 3 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 11, 3 resimden 2. Panasonic SA-PM17 CD Tray Cover Replacement: adım 11, 3 resimden 3.
    • Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
    FixBot'a Sor
  12. Panasonic SA-PM17 CD Tray Cover Replacement: adım 12, 2 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 12, 2 resimden 2.
    • Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
    FixBot'a Sor
  13. Panasonic SA-PM17 CD Tray Cover Replacement: adım 13, 3 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 13, 3 resimden 2. Panasonic SA-PM17 CD Tray Cover Replacement: adım 13, 3 resimden 3.
    • Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
    • Rotate device 180 degrees and repeat for other side.
    • Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
    FixBot'a Sor
  14. Panasonic SA-PM17 CD Tray Cover Replacement: adım 14, 1 resimden 1.
    • Wiggle the front gently while pulling it forward until it comes free of the body of the device.
    FixBot'a Sor
  15. Panasonic SA-PM17 CD Tray Cover Replacement, CD Tray Cover: adım 15, 1 resimden 1.
    • Remove the two 11.5 mm screws indicated and set aside in a safe place.
    FixBot'a Sor
  16. Panasonic SA-PM17 CD Tray Cover Replacement: adım 16, 2 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 16, 2 resimden 2.
    • Using tweezers, remove the two restraints indicated and place with the screws removed in the previous step.
    FixBot'a Sor
  17. Panasonic SA-PM17 CD Tray Cover Replacement: adım 17, 2 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 17, 2 resimden 2.
    • Remove the spring from its slot using tweezers.
    FixBot'a Sor
  18. Panasonic SA-PM17 CD Tray Cover Replacement: adım 18, 1 resimden 1.
    • Using tweezers or fingers, pull firmly on the base of this cord until it pops out of its slot.
    FixBot'a Sor
  19. Panasonic SA-PM17 CD Tray Cover Replacement: adım 19, 2 resimden 1. Panasonic SA-PM17 CD Tray Cover Replacement: adım 19, 2 resimden 2.
    • Lift the pegs of the cover up while rotating the rest of the part down and out of the device.
    • If at first the cover does not come free, wiggle it around a bit until it does, but do not force it out.
    • Do not to lose this spring while replacing the cover.
    FixBot'a Sor
Sonuç
NathanB
418 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-1, Regan Spring 2011 Cal Poly, Team 4-1, Regan Spring 2011 üyesi
CPSU-REGAN-S11S4G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 73
Her zaman: 5,390
