Ana içeriğe geç
Panasonic SA-PM17 CD Tray Unit Replacement
Neye ihtiyacın var
  1. Panasonic SA-PM17 CD Tray Unit Replacement, Disassembling front of the Panasonic SA-PM17: adım 1, 2 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement, Disassembling front of the Panasonic SA-PM17: adım 1, 2 resimden 2.
    • Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Panasonic SA-PM17 CD Tray Unit Replacement: adım 2, 1 resimden 1.
    • Remove these seven 11.5 mm screws and place aside.
    FixBot'a Sor
    Yorum Ekle
  3. Panasonic SA-PM17 CD Tray Unit Replacement: adım 3, 1 resimden 1.
    • Lift the right side off of the device and place aside.
    • Repeat for left side.
    FixBot'a Sor
    Yorum Ekle
  4. Panasonic SA-PM17 CD Tray Unit Replacement: adım 4, 1 resimden 1.
    • Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
    • Do not pull the top too far as there are wires attached to it.
    FixBot'a Sor
    Yorum Ekle
  5. Panasonic SA-PM17 CD Tray Unit Replacement: adım 5, 2 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 5, 2 resimden 2.
    • Gently lift up on the indicated tabs to disengage them from the hooks holding them in place.
    FixBot'a Sor
    Yorum Ekle
  6. Panasonic SA-PM17 CD Tray Unit Replacement: adım 6, 1 resimden 1.
    • Lift up the top while firmly sliding it towards the back of the device.
    • Do not lift the top up too high as there are cords that need to be detached before the top can be removed.
    • The next step is a zoom-in of the indicated area.
    FixBot'a Sor
    Yorum Ekle
  7. Panasonic SA-PM17 CD Tray Unit Replacement: adım 7, 1 resimden 1.
    • Using forceps or fingers, remove the small black wire indicated.
    • Grip the wire near its base and pull gently but firmly until it pops out of the slot.
    FixBot'a Sor
    Yorum Ekle
  8. Panasonic SA-PM17 CD Tray Unit Replacement: adım 8, 3 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 8, 3 resimden 2. Panasonic SA-PM17 CD Tray Unit Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • This step deals with the indicated area of the device.
    • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
    • Gently pull on the cord near its base until it comes free of the restraint.
    FixBot'a Sor
    Yorum Ekle
  9. Panasonic SA-PM17 CD Tray Unit Replacement: adım 9, 3 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 9, 3 resimden 2. Panasonic SA-PM17 CD Tray Unit Replacement: adım 9, 3 resimden 3.
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it comes free of the attachment.
    • The top section of the device should now be free of the body. Place it aside in a safe place.
    FixBot'a Sor
    Yorum Ekle
  10. Panasonic SA-PM17 CD Tray Unit Replacement: adım 10, 3 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 10, 3 resimden 2. Panasonic SA-PM17 CD Tray Unit Replacement: adım 10, 3 resimden 3.
    • This step deals with the indicated portion of the the device.
    • Lift the indicated tabs out until they look like the final picture.
    • Gently pull on the cord until it comes free of its restraint.
    FixBot'a Sor
    Yorum Ekle
  11. Panasonic SA-PM17 CD Tray Unit Replacement: adım 11, 3 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 11, 3 resimden 2. Panasonic SA-PM17 CD Tray Unit Replacement: adım 11, 3 resimden 3.
    • Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
    FixBot'a Sor
    Yorum Ekle
  12. Panasonic SA-PM17 CD Tray Unit Replacement: adım 12, 2 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 12, 2 resimden 2.
    • Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
    FixBot'a Sor
    Yorum Ekle
  13. Panasonic SA-PM17 CD Tray Unit Replacement: adım 13, 3 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 13, 3 resimden 2. Panasonic SA-PM17 CD Tray Unit Replacement: adım 13, 3 resimden 3.
    • Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
    • Rotate device 180 degrees and repeat for other side.
    • Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
    FixBot'a Sor
    Yorum Ekle
  14. Panasonic SA-PM17 CD Tray Unit Replacement: adım 14, 1 resimden 1.
    • Wiggle the front gently while pulling it forward until it comes free of the body of the device.
    FixBot'a Sor
    Yorum Ekle
  15. Panasonic SA-PM17 CD Tray Unit Replacement, CD Tray Unit: adım 15, 2 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement, CD Tray Unit: adım 15, 2 resimden 2.
    • Using tweezers or fingers, pull gently but firmly on the base of the cord until it comes free of its slot.
    FixBot'a Sor
    Yorum Ekle
  16. Panasonic SA-PM17 CD Tray Unit Replacement: adım 16, 2 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 16, 2 resimden 2.
    • Using a philips screwdriver, remove the four 9.5 mm screws indicated and place aside.
    FixBot'a Sor
    Yorum Ekle
  17. Panasonic SA-PM17 CD Tray Unit Replacement: adım 17, 3 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 17, 3 resimden 2. Panasonic SA-PM17 CD Tray Unit Replacement: adım 17, 3 resimden 3.
    • Lift the body directly up off of the base and place aside.
    • Note the proper locations of the various tabs in the last picture.
    FixBot'a Sor
    Yorum Ekle
  18. Panasonic SA-PM17 CD Tray Unit Replacement: adım 18, 3 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 18, 3 resimden 2. Panasonic SA-PM17 CD Tray Unit Replacement: adım 18, 3 resimden 3.
    • Remove the two 9.5 mm screws indicated using an extended screwdriver.
    • Use a flashlight to view the screw on the left.
    FixBot'a Sor
    Yorum Ekle
  19. Panasonic SA-PM17 CD Tray Unit Replacement: adım 19, 2 resimden 1. Panasonic SA-PM17 CD Tray Unit Replacement: adım 19, 2 resimden 2.
    • Lift the CD Tray Unit off of the bottom of the device and replace with new unit.
    • When placing the new unit in, verify that the indicated pin is in its proper slot before putting the screws back on.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
NathanB
418 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-1, Regan Spring 2011 Cal Poly, Team 4-1, Regan Spring 2011 üyesi
CPSU-REGAN-S11S4G1
3 Üyeler
8Kılavuz Yorumları
I have one of these units and I'm wondering if the author of this guide knows where to find the parts? I'm assuming that I'll need a replacement Tray Unit. Mine does not open. Should there be any sound if there is something mechanical wrong? I don't hear anything, I just see the display flashing "CDx Opening" ...
Perhaps this is a wiring fault rather than a mechanical one?
Timothy Cahill - Yanıt Paylaş
In order to unblock the trays:
The white cover piece can be taken off by moving it a little backwards and pressing the two resistance pieces on top at 1/3 back.
The trays have a cograil at the left side (when looking from the front of the device), which sometimes gets displaced respective to a white cog at the left backward side. It is possible to pull them out, but it is much more difficult to push them back once they are out. In order to achieve this that you need to force a screwdriver inside in order to separate the cograil from a white plastic cog, and then to force (but not too much!!) the tray backwards. In case it is not the tray no 5 (the one most on top) you need to free the more downwards located trays by pulling out all trays above and position them back as described.
Make sure that all trays are in a good position at the end.
Switch the cd device off before manipulating as the mechanism easily gets blocked when in tilted positions. The switch off moves them all back to primary position.
Markus - Yanıt Paylaş
This is also true for the model Parasonic SA-PM18
3 years late to the game...i have a question but no technical terms.
I have the SA-PM18. The CD1 draw doesn't stay secure and when I turn on the player it makes a churning noise.
The 2 possible reasons:
-the little cog on the outer left near the front isn't secure, if i push it up it will fall down again, I dont know if this is normal.
-(more likely) the little white parts half way up on the INNER left that (maybe) keep the trays in place is pushed back somehow and I can't get it to come back in place.
The black casing around this is all 1 piece so I can't open it up to get to it.
Is there a way to fix this without having to replace the whole tray unit?
Madi F - Yanıt Paylaş
the CD trays would not open ... what can I do ?
argouarch - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 29
Son 30 gün: 108
Her zaman: 18,995
