Ana içeriğe geç
Panasonic SA-PM17 Tape Player Unit Replacement
Neye ihtiyacın var
  1. Panasonic SA-PM17 Tape Player Unit Replacement, Tape Player Unit: adım 1, 2 resimden 1. Panasonic SA-PM17 Tape Player Unit Replacement, Tape Player Unit: adım 1, 2 resimden 2.
    • With a Phillips #0 screwdriver, remove the eight 9.5mm screws attached to the left and right panels of the device.
  2. Panasonic SA-PM17 Tape Player Unit Replacement: adım 2, 1 resimden 1.
    • With a Phillips #0 screwdriver, remove the five 11.5mm screws attached to the backside panel of the device.
    • Organize and label screws into a Ziploc bag for an easier resemble process.
  3. Panasonic SA-PM17 Tape Player Unit Replacement: adım 3, 1 resimden 1.
    • Detach the right and left panels from the device.
  4. Panasonic SA-PM17 Tape Player Unit Replacement: adım 4, 1 resimden 1.
    • Lift the top panel and gently place alongside the device.
    • Allow the top panel to rest on the back without reattaching it.
    • CAUTION: Do not extend the top panel too far from the device due to the connected wires.
  5. Panasonic SA-PM17 Tape Player Unit Replacement: adım 5, 2 resimden 1. Panasonic SA-PM17 Tape Player Unit Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • With the tweezers, detach the indicated tabs from the hooks by lifting upward.
    • Disconnecting the tabs will release a portion of the front panel connected to the entire device.
  6. Panasonic SA-PM17 Tape Player Unit Replacement: adım 6, 1 resimden 1.
    • Lift the top panel upward while firmly sliding it towards the back of the device.
    • The wires connected to the top panel will need to be disconnected in order to completely detach the panel.
  7. Panasonic SA-PM17 Tape Player Unit Replacement: adım 7, 2 resimden 1. Panasonic SA-PM17 Tape Player Unit Replacement: adım 7, 2 resimden 2.
    • Disconnect the black wire by gripping the wire at the base and pulling gently until released.
  8. Panasonic SA-PM17 Tape Player Unit Replacement: adım 8, 3 resimden 1. Panasonic SA-PM17 Tape Player Unit Replacement: adım 8, 3 resimden 2. Panasonic SA-PM17 Tape Player Unit Replacement: adım 8, 3 resimden 3.
    • This step deals with the indicated area of the device.
    • Using the tweezers, detach the indicated tabs so that the cord may be released from the restraints.
    • Gently pull on the cord, near its base, until it comes free of the restraint.
  9. Panasonic SA-PM17 Tape Player Unit Replacement: adım 9, 3 resimden 1. Panasonic SA-PM17 Tape Player Unit Replacement: adım 9, 3 resimden 2. Panasonic SA-PM17 Tape Player Unit Replacement: adım 9, 3 resimden 3.
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it is released from the attachment.
    • The top panel is now disconnected from the device.
  10. Panasonic SA-PM17 Tape Player Unit Replacement: adım 10, 2 resimden 1. Panasonic SA-PM17 Tape Player Unit Replacement: adım 10, 2 resimden 2.
    • Remove the four 12.1mm screws using a Phillips #0 screwdriver.
    • Organize and label screws into a Ziploc bag for safe keeping and easier resembling process.
  11. Panasonic SA-PM17 Tape Player Unit Replacement: adım 11, 3 resimden 1. Panasonic SA-PM17 Tape Player Unit Replacement: adım 11, 3 resimden 2. Panasonic SA-PM17 Tape Player Unit Replacement: adım 11, 3 resimden 3.
    • This step deals with the indicated area.
    • Using the tweezers, pull the indicated latch to the right to disconnect the tape player unit from the top of the device.
    • While holding the latch to the right, lift the unit up from the plastic.
    • CAUTION: When the latch is disengaged, the tape cover may push out and force the rest of the apparatus to pop up. This is normal, but be careful that the tape cover does not pop out too quickly.
    • NOTE: When placing this unit back on the device, you can simply push the unit into position. The latch will automatically snap into position.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
NathanB
418 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-1, Regan Spring 2011 Cal Poly, Team 4-1, Regan Spring 2011 üyesi
CPSU-REGAN-S11S4G1
3 Üyeler
2Kılavuz Yorumları
The problem with my micro system pm17 is that the tape drive's head does not work. I noticed that it is a gear that has the function to trigger,The gearbox has probably moved out of its original position and is now not turning the read head.How do I return the gear to the original position so that it re-engages the bedhead?
Rogerio - Yanıt
Add a comment
Rogerio - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 28
Her zaman: 3,611
