Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Unscrew the four  4 mm screws on the bottom of the camcorder. The screws are two different colors: three black, one silver.
    • Unscrew the four 4 mm screws on the bottom of the camcorder.
    • The screws are two different colors: three black, one silver.
  2. Unscrew the three 6 mm screws on the handstrap-side of the camcorder.
    • Unscrew the three 6 mm screws on the handstrap-side of the camcorder.
  3. Pull the charging port (DC input terminal) cover back and remove the 4 mm screw located next to the input terminal.
    • Pull the charging port (DC input terminal) cover back and remove the 4 mm screw located next to the input terminal.
  4. Unscrew the two black 4 mm screws   underneath the LCD Monitor. One screw is located by the hinge of the LCD Monitor. The second is  close to the upper-back corner of the camcorder body.
    • Unscrew the two black 4 mm screws underneath the LCD Monitor.
    • One screw is located by the hinge of the LCD Monitor. The second is close to the upper-back corner of the camcorder body.
    • Pull the casing under the hand strap directly outward until casing detaches from camcorder
    • Detach gently so the ribbon cable is not damaged!
  5. Use tweezers to grab the ribbon cable at the connection point and slowly lift up until the connection is separated.
    • Use tweezers to grab the ribbon cable at the connection point and slowly lift up until the connection is separated.
    • This point connects the HDD to the motherboard.
  6. On the casing with the HDD, unscrew the two silver 4 mm screws on the upper interior.
    • On the casing with the HDD, unscrew the two silver 4 mm screws on the upper interior.
  7. Pull the plastic black brace where the screws were attached gently with your hand to gain access to the HDD.
    • Pull the plastic black brace where the screws were attached gently with your hand to gain access to the HDD.
    • The black brace will be able to come apart from the camcorder.
  8. Pry under the HDD gently with a plastic opening tool, and the HDD should easily come out of the casing.
    • Pry under the HDD gently with a plastic opening tool, and the HDD should easily come out of the casing.
  9. The HDD is now out (The HDD is ready to be replaced).
    • The HDD is now out (The HDD is ready to be replaced).
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 7
Her zaman: 510
