Ana içeriğe geç
Panasonic SDR-H85 LCD Replacement
Neye ihtiyacın var
  1. Panasonic SDR-H85 LCD Replacement, Battery: adım 1, 3 resimden 1. Panasonic SDR-H85 LCD Replacement, Battery: adım 1, 3 resimden 2. Panasonic SDR-H85 LCD Replacement, Battery: adım 1, 3 resimden 3.
    • Gently slide the battery ejection button which is located underneath the battery and slide the battery out.
    • Once the battery is removed, you can safely dispose it and replace with a new one. Dispose battery at an authorized battery recycling center.
  2. Panasonic SDR-H85 LCD Replacement, LCD Screen: adım 2, 2 resimden 1. Panasonic SDR-H85 LCD Replacement, LCD Screen: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove two screws from behind the corners of the display screen.
  3. Panasonic SDR-H85 LCD Replacement: adım 3, 2 resimden 1. Panasonic SDR-H85 LCD Replacement: adım 3, 2 resimden 2.
    • Open the case carefully. Make sure to disconnect the parts.
  4. Panasonic SDR-H85 LCD Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove one screw on the green panel.
  5. Panasonic SDR-H85 LCD Replacement: adım 5, 3 resimden 1. Panasonic SDR-H85 LCD Replacement: adım 5, 3 resimden 2. Panasonic SDR-H85 LCD Replacement: adım 5, 3 resimden 3.
    • Disconnect the panel from the screen part.
Sonuç
Ying Liu
109 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 532
