Ana içeriğe geç
Panasonic Toughbook CF-29 Back Cover Replacement
Neye ihtiyacın var
  1. Panasonic Toughbook CF-29 Back Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Back Cover Replacement: adım 2, 2 resimden 1. Panasonic Toughbook CF-29 Back Cover Replacement: adım 2, 2 resimden 2.
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Back Cover Replacement, Optical Drive: adım 3, 1 resimden 1.
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Back Cover Replacement: adım 4, 1 resimden 1.
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Back Cover Replacement: adım 5, 2 resimden 1. Panasonic Toughbook CF-29 Back Cover Replacement: adım 5, 2 resimden 2.
    • Push the exposed switch to the left to eject the optical drive.
  6. Panasonic Toughbook CF-29 Back Cover Replacement, Back Cover: adım 6, 1 resimden 1.
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  7. Panasonic Toughbook CF-29 Back Cover Replacement: adım 7, 1 resimden 1.
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  8. Panasonic Toughbook CF-29 Back Cover Replacement: adım 8, 1 resimden 1.
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  9. Panasonic Toughbook CF-29 Back Cover Replacement: adım 9, 2 resimden 1. Panasonic Toughbook CF-29 Back Cover Replacement: adım 9, 2 resimden 2.
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  10. Panasonic Toughbook CF-29 Back Cover Replacement: adım 10, 1 resimden 1.
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  11. Panasonic Toughbook CF-29 Back Cover Replacement: adım 11, 1 resimden 1.
    • Now the back cover should be off and you can access the inside of the casing.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Rohun Heesen
426 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G93
4 Üyeler
26 adet Kılavuz yazıldı
Bir Yorum
thanks for this crucial tuatorial >
Joe Gutierrez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 10,050
