Giriş
This guide will tell you how to gain access to and remove the motherboard.
Parçalar
Hiçbir parça belirtilmedi.
Flip the device upside down with the handle facing away from you.
Open the optical drive bay by sliding its latch to the right.
Locate optical drive release mechanism on the bottom of the laptop.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the black and white wires attached to the wireless card by simply pulling up.
Unplug 3 cables
Lift up on brown tab to release cable
Pull cable up and out
4 farklı kişi bu kılavuzu tamamladı.
2 Comments
what about spare parts? is it possible cange MOBO and CPU? in order to upgrade the thoughbook?
