Ana içeriğe geç
Panasonic Toughbook CF-53 Battery Replacement
  1. Panasonic Toughbook CF-53 Battery Replacement, Battery: adım 1, 3 resimden 1. Panasonic Toughbook CF-53 Battery Replacement, Battery: adım 1, 3 resimden 2. Panasonic Toughbook CF-53 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Orient the laptop on its side so that the plastic battery cover is facing upward.
    • Push down on the battery cover and remove it by sliding the cover down. This may take some force, but the cover should pop up with a soft click.
  2. Panasonic Toughbook CF-53 Battery Replacement: adım 2, 2 resimden 1. Panasonic Toughbook CF-53 Battery Replacement: adım 2, 2 resimden 2.
    • Use the battery release slider to release the battery latch.
  3. Panasonic Toughbook CF-53 Battery Replacement: adım 3, 3 resimden 1. Panasonic Toughbook CF-53 Battery Replacement: adım 3, 3 resimden 2. Panasonic Toughbook CF-53 Battery Replacement: adım 3, 3 resimden 3.
    • Use the blue tab to pull the battery out of the battery compartment. Make sure to keep the battery latch tab depressed while doing so.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I replaced the battery compatible one and replace the power adapter as well but still shows no power. What other issues may cause no power?
Rick Reeves - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 31
Son 30 gün: 120
Her zaman: 5,791
