Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
One common point of failure in laptops is the battery. This component can suffer a range of issues from completely dying, holding a significantly lower change than it did originally, or even not outputting the correct voltage. The Panasonic Toughbook CF-53 utilizes a quick release battery to allow users to swap batteries when needed.
Orient the laptop on its side so that the plastic battery cover is facing upward.
Push down on the battery cover and remove it by sliding the cover down. This may take some force, but the cover should pop up with a soft click.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I replaced the battery compatible one and replace the power adapter as well but still shows no power. What other issues may cause no power?
