Ana içeriğe geç
Panasonic Toughbook CF-53 Optical Drive Replacement
Neye ihtiyacın var
  1. Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 1. Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 2.
    • Orient the laptop onto its top and face the bottom towards you.
    • Remove the 3 mm Phillips #00 screws securing the Wi-Fi card/optical drive plastic cover.
  2. Panasonic Toughbook CF-53 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Remove the 5 mm Phillips #00 screw on the silver tab to the left.
  3. Panasonic Toughbook CF-53 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Reach under the silver tab and push the optical drive out of the side of the device using a spudger.
  4. Panasonic Toughbook CF-53 Optical Drive Replacement: adım 4, 1 resimden 1.
    • Now that the drive is completely disconnected from the device, slide the optical drive out of its slot.
    • The end of the drive may seem to be stuck inside the device during removal. If this is the case gently wiggle the drive side to side and apply a small force until it pops free.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 1,544
