Ana içeriğe geç
Panasonic Toughbook CF-53 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Panasonic Toughbook CF-53 Wi-Fi Card Replacement, Wi-Fi & Bluetooth Card: adım 1, 3 resimden 1. Panasonic Toughbook CF-53 Wi-Fi Card Replacement, Wi-Fi & Bluetooth Card: adım 1, 3 resimden 2. Panasonic Toughbook CF-53 Wi-Fi Card Replacement, Wi-Fi & Bluetooth Card: adım 1, 3 resimden 3.
    • Turn the laptop to its back side and align it so that the handle is facing away from you.
    • Remove the single 4 mm Phillips #00 screw from the Wi-Fi card/optical drive cover and remove the plastic cover.
    • The Wi-Fi card is located closest to you , below the little strip-sized circuit board.
  2. Panasonic Toughbook CF-53 Wi-Fi Card Replacement: adım 2, 2 resimden 1. Panasonic Toughbook CF-53 Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Very gently pry up on the two connectors attached to the Wi-Fi card using the flat end of a spudger.
    • It is very important to be careful with these connectors because they are difficult to replace or repair.
    • Once both connectors have been detached, carefully hold the wires back to have access to the Wi-Fi card.
  3. Panasonic Toughbook CF-53 Wi-Fi Card Replacement: adım 3, 3 resimden 1. Panasonic Toughbook CF-53 Wi-Fi Card Replacement: adım 3, 3 resimden 2. Panasonic Toughbook CF-53 Wi-Fi Card Replacement: adım 3, 3 resimden 3.
    • Remove the two 4 mm Phillips #00 screws that secure the card to the board.
    • Gently lift the card up and pull it out of its connection slot.
    • The Wi-Fi card is now removed.
    • When inserting the new Wi-Fi card into the connection slot, place the card at a 40 degree angle and push it all the way back, then lay it flat.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 63
Her zaman: 2,869
