Ana içeriğe geç
Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement
Neye ihtiyacın var
  1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement, AV and Micro USB Data Ports: adım 1, 3 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement, AV and Micro USB Data Ports: adım 1, 3 resimden 2. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement, AV and Micro USB Data Ports: adım 1, 3 resimden 3.
    • Use your Phillips #0 screwdriver to remove the three 5mm screws on top of the camera.
    • Remove the metal bracket.
  2. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 2, 2 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 2, 2 resimden 2.
    • Rotate the camera to show the bottom of the camera.
    • Remove the four 5mm screws on the bottom side of the camera with a Phillips #0 driver.
  3. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 3, 2 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 3, 2 resimden 2.
    • Rotate the camera to the left side. There is one screw on the top right of metal bracket you have removed in step 1.
    • Remove one 5mm screw by using Phillips #0 screwdriver.
  4. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 4, 2 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 4, 2 resimden 2.
    • Use a plastic spudger to lighty pry the top-front panel of the camera from the main body.
    • Slide the top portion of the camera forward revealing more screws.
    • Do not completely separate the top portion yet, as there are cable connections that remain.
  5. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 5, 3 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 5, 3 resimden 2. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 5, 3 resimden 3.
    • Flip the camera on the right side.
    • Gently pull the front part from the main body to expose the cable connections.
    • Pulling too hard or fast has the potential to damage the ZIF connector cable.
    • Use your plastic opening tool to disconnect the connection point safely.
    • Press the tab with plastic opening tool and then pull the ZIF connector to detach.
  6. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 6, 1 resimden 1.
    • Flip the camera to see the top side of it.
    • Remove one more 5mm screw with your Phillips #0 screwdriver that was previously covered by the front-top section.
  7. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 7, 2 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 7, 2 resimden 2.
    • Go to the battery's basement side.
    • Use your Phillips #0 screwdriver remove the two 5mm screws on the battery base of the camera.
  8. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 8, 3 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 8, 3 resimden 2. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 8, 3 resimden 3.
    • Rotate the camera to the left side, where the side port is located.
    • Open the side port door.
  9. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 9, 3 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 9, 3 resimden 2. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 9, 3 resimden 3.
    • Remove three 5mm screws inside the side ports by using Phillips #0 screwdriver.
    • Start to lift the lefthand section of the camera from the main body.
    • Don't fully remove the section just yet as there are cable connections that remain.
  10. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 10, 3 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 10, 3 resimden 2. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 10, 3 resimden 3.
    • Rotate the camera to the battery side.
    • Gently, pull the side of the camera apart with only your hands.
    • Do not pull too hard because of the ZIF connector cable.
    • Disconnect the ribbon cable with your plastic opening tool, so that the left side of the camera can be removed.
  11. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 11, 2 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 11, 2 resimden 2.
    • Remove one 5mm screw from the side of the battery base with the Phillips #0 screwdriver.
    • Take off the battery's base from the camera.
  12. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 12, 2 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 12, 2 resimden 2.
    • Rotate the camera to the bottom side.
    • Remove six 5mm screws with your Phillips #0 driver and the circuit board holder should come free.
  13. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 13, 2 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 13, 2 resimden 2.
    • Insert a Jimmy tool to relieve the pressure between the metal mount and the plastic cover.
    • Take off the port board from the bottom of the camera.
  14. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 14, 3 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 14, 3 resimden 2. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 14, 3 resimden 3.
    • Use your Phillips #0 screwdriver remove one 5mm screw from one side of the port.
    • On the other side, disconnect the metal from the port circuit board smoothly.
  15. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 15, 2 resimden 1. Panasonic VDR-D220 DVD AV and Micro USB Data Ports Replacement: adım 15, 2 resimden 2.
    • Remove the metal cover from the side port.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 251
