Ana içeriğe geç
Panasonic VDR-D220 DVD Camera Front lens Element Replacement
Neye ihtiyacın var
  1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: adım 1, 3 resimden 1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: adım 1, 3 resimden 2. Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: adım 1, 3 resimden 3.
    • Remove one 5mm screw on the bottom side of the camera with a Phillips #0 screwdriver.
  2. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 2, 3 resimden 1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 2, 3 resimden 2. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 2, 3 resimden 3.
    • Open the side port door.
  3. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 3, 2 resimden 1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 3, 2 resimden 2.
    • Remove one 5mm screw inside the side port with your Phillips #0 screwdriver.
  4. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 4, 2 resimden 1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 4, 2 resimden 2.
    • Using a plastic spudger, pry to disconnect the top-front part of the camera.
    • Slide the top portion of the camera forward revealing a ribbon cable.
  5. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 5, 3 resimden 1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 5, 3 resimden 2. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 5, 3 resimden 3.
    • Flip the camera on the right side.
    • Gently pull the front part from the main body to reveal the cables connecting them.
    • Do not pull too hard because of the ZIF connector cable.
    • Use your plastic opening tool to disconnect the connection point safely.
    • Press the tab with a plastic opening tool and then pull the ZIF connector to detach.
  6. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 6, 3 resimden 1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 6, 3 resimden 2. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 6, 3 resimden 3.
    • Look at the camera from the front side.
    • Remove four 5mm screws using a Phillips #0 screwdriver.
    • There are two 5mm screws on each side of the lens, for a total of four screws.
  7. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 7, 3 resimden 1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 7, 3 resimden 2. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: adım 7, 3 resimden 3.
    • Pull the front element lens gently away from the camera.
    • In some cases the lens need not be replaced completely. Sometimes cleaning the lens with a microfiber cloth and isopropyl alcohol will alleviate blurry video issues.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 173
