Ana içeriğe geç
Panasonic VDR-D220 DVD Disk Latch Replacement
Neye ihtiyacın var
  1. Panasonic VDR-D220 DVD Disk Latch Replacement, Disk Latch: adım 1, 2 resimden 1. Panasonic VDR-D220 DVD Disk Latch Replacement, Disk Latch: adım 1, 2 resimden 2.
    • The DVD's door can be opened by pressing the top-left of the DVD's door.
    • If this doesn’t work, you may need to manually eject.
    • Use the plastic spudger with light force to carefully pry open the door.
    • Open the disk ejection slot gently.
  2. Panasonic VDR-D220 DVD Disk Latch Replacement: adım 2, 3 resimden 1. Panasonic VDR-D220 DVD Disk Latch Replacement: adım 2, 3 resimden 2. Panasonic VDR-D220 DVD Disk Latch Replacement: adım 2, 3 resimden 3.
    • Remove the two 5mm screws on the top-right corner of the disk slot using Phillips #0 screwdriver.
  3. Panasonic VDR-D220 DVD Disk Latch Replacement: adım 3, 2 resimden 1. Panasonic VDR-D220 DVD Disk Latch Replacement: adım 3, 2 resimden 2.
    • Carefully remove the chip.
    • The disk is completely replaced/removed.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 126
