Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Mother board issues is the most common problem on older technology such as this camera. Moisture can get in form all of its usage and short out the most critical components of this device. Here it will be explained how to access and remove this faulty board.
Neye ihtiyacın var
Use your Phillips #0 screwdriver to remove the three 5mm screws on top of the camera.
Remove the metal bracket.
Flip the camera on the right side.
Gently pull the front part away from the main body to expose the cable connections holding them together.
Use your plastic opening tool to disconnect the connection point safely.
Press the tab with plastic opening tool and then pull the ZIF connector to detach.
Bir başkası bu kılavuzu tamamladı.
