Ana içeriğe geç
Pandigital Novel PRD07T10WWH7 Battery Replacement
Neye ihtiyacın var
  1. Pandigital Novel PRD07T10WWH7 Battery Replacement, Battery: adım 1, 2 resimden 1. Pandigital Novel PRD07T10WWH7 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back panel by sliding it downwards and pushing in slightly.
  2. Pandigital Novel PRD07T10WWH7 Battery Replacement: adım 2, 2 resimden 1. Pandigital Novel PRD07T10WWH7 Battery Replacement: adım 2, 2 resimden 2.
    • Pry off the second white panel, removing two clips underneath.
    • Start from the middle, and then work on the sides. The sides may be difficult to remove, so try to focus on one side and work your way around.
  3. Pandigital Novel PRD07T10WWH7 Battery Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the 12 4mm screws on the outer area of the gray area exposed by removing the back panels.
  4. Pandigital Novel PRD07T10WWH7 Battery Replacement: adım 4, 2 resimden 1. Pandigital Novel PRD07T10WWH7 Battery Replacement: adım 4, 2 resimden 2.
    • Carefully pry the back of the device from the front panel and motherboard. There are a series of clips holding them together that need to be separated.
  5. Pandigital Novel PRD07T10WWH7 Battery Replacement: adım 5, 2 resimden 1. Pandigital Novel PRD07T10WWH7 Battery Replacement: adım 5, 2 resimden 2.
    • Now, lift up the gray piece, unplug the battery connector, and the battery can be removed from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carl Weber
328 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-7, Isaacson Fall 2016 UMass Dartmouth, Team 3-7, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,237
