Ana içeriğe geç
Pandigital Novel PRD07T10WWH7 SD Card Replacement
Neye ihtiyacın var
  1. Pandigital Novel PRD07T10WWH7 SD Card Replacement, SD Card: adım 1, 3 resimden 1. Pandigital Novel PRD07T10WWH7 SD Card Replacement, SD Card: adım 1, 3 resimden 2. Pandigital Novel PRD07T10WWH7 SD Card Replacement, SD Card: adım 1, 3 resimden 3.
    • Remove the two white panels on the back of the device, starting with the bottom one by pushing in and down.
    • Then, to remove the top white piece, use the plastic opening tool to start in the middle and remove the clips, working your way around.
  2. Pandigital Novel PRD07T10WWH7 SD Card Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #0 bit, remove the 12 4mm screws.
  3. Pandigital Novel PRD07T10WWH7 SD Card Replacement: adım 3, 3 resimden 1. Pandigital Novel PRD07T10WWH7 SD Card Replacement: adım 3, 3 resimden 2. Pandigital Novel PRD07T10WWH7 SD Card Replacement: adım 3, 3 resimden 3.
    • Pry the gray piece off of the motherboard.
    • Make sure the unplug the battery before you fully separate the gray piece.
  4. Pandigital Novel PRD07T10WWH7 SD Card Replacement: adım 4, 2 resimden 1. Pandigital Novel PRD07T10WWH7 SD Card Replacement: adım 4, 2 resimden 2.
    • Push upwards on the SD card slot to release it.
  5. Pandigital Novel PRD07T10WWH7 SD Card Replacement: adım 5, 2 resimden 1. Pandigital Novel PRD07T10WWH7 SD Card Replacement: adım 5, 2 resimden 2.
    • The SD card can now be removed safely.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carl Weber
328 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-7, Isaacson Fall 2016 UMass Dartmouth, Team 3-7, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 421
