Ana içeriğe geç
Pandigital Novel PRD07T10WWH7 Screen Replacement
Neye ihtiyacın var
  1. Pandigital Novel PRD07T10WWH7 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Remove the back panel by sliding it downwards and pushing in slightly.
  2. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 2, 3 resimden 1. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 2, 3 resimden 2. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 2, 3 resimden 3.
    • Pry off the second white panel, removing two clips underneath.
    • Start from the middle, and then work on the sides. The sides may be difficult to remove, so try to focus on one side and work your way around.
  3. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #0 bit, remove the 12 4mm screws on the outer area of the gray area exposed by removing the back panels.
  4. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 4, 2 resimden 1. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 4, 2 resimden 2.
    • Carefully pry the back of the device from the front panel and motherboard. There are a series of clips holding them together that need to be separated.
  5. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 5, 1 resimden 1.
    • Now, lift up the gray piece, unplug the battery connector, so the gray piece will come free from the rest of the device.
  6. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 6, 2 resimden 1. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 6, 2 resimden 2.
    • Use the tip of your plastic spudger or your fingernail to flip up the long retaining flap. The longer, gold ribbon cable can now be pulled out safely.
  7. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 7, 2 resimden 1. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 7, 2 resimden 2.
    • Use the tip of your plastic spudger or your fingernail to flip up the shorter retaining flap. The smaller gold ribbon cable can now be pulled out safely.
  8. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 8, 2 resimden 1. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 8, 2 resimden 2.
    • Starting from the side of the device, lift the motherboard off of the plastic standoffs.
    • You will need to peel both speakers off of the device's plastic frame.
  9. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 9, 2 resimden 1. Pandigital Novel PRD07T10WWH7 Screen Replacement: adım 9, 2 resimden 2.
    • With the screen facing up, use a plastic opening tool along the sides of the screen to pry it away from the motherboard.
    • There are six adhesive pads holding the display in place.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Samuel Carey
401 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-7, Isaacson Fall 2016 UMass Dartmouth, Team 3-7, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 762
