Ana içeriğe geç
Pandigital Super Nova Front Facing Camera Replacement
Neye ihtiyacın var
  1. Pandigital Super Nova Front Facing Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the screw covers from each corner of the back side of the device.
    • Set aside.
  2. Pandigital Super Nova Front Facing Camera Replacement: adım 2, 2 resimden 1. Pandigital Super Nova Front Facing Camera Replacement: adım 2, 2 resimden 2.
    • Using a Philips screwdriver, remove all four .15 mm screws from each corner.
    • Set aside.
  3. Pandigital Super Nova Front Facing Camera Replacement: adım 3, 1 resimden 1.
    • Using the plastic opening tool, remove the back cover of the device.
  4. Pandigital Super Nova Front Facing Camera Replacement: adım 4, 1 resimden 1.
    • Remove the three .11 mm screws that hold the battery in place.
    • Set aside.
  5. Pandigital Super Nova Front Facing Camera Replacement: adım 5, 2 resimden 1. Pandigital Super Nova Front Facing Camera Replacement: adım 5, 2 resimden 2.
    • Unplug the battery and remove from device.
    • Avoid touching the motherboard as it is fragile.
  6. Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: adım 6, 2 resimden 1. Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: adım 6, 2 resimden 2.
    • Use a metal pry tool to separate the camera and the small clip that holds it in place.
    • Do NOT touch the MotherBoard with your bare hands. There is risk of short circuiting the device. Use nitrile gloves to prevent this.
  7. Pandigital Super Nova Front Facing Camera Replacement: adım 7, 2 resimden 1. Pandigital Super Nova Front Facing Camera Replacement: adım 7, 2 resimden 2.
    • Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
Sonuç
sterling hannsz
267 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 1-2, Bennett Fall 2016 Texas Tech, Team 1-2, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 105
