Ana içeriğe geç
Pandigital Super Nova Screen Replacement
Neye ihtiyacın var
  1. Pandigital Super Nova Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the screw covers from each corner of the back side of the device.
    • Set aside.
  2. Pandigital Super Nova Screen Replacement: adım 2, 2 resimden 1. Pandigital Super Nova Screen Replacement: adım 2, 2 resimden 2.
    • Using a Philips screwdriver, remove all four .15 mm screws from each corner.
    • Set aside.
  3. Pandigital Super Nova Screen Replacement: adım 3, 1 resimden 1.
    • Using the plastic opening tool, remove the back cover of the device.
  4. Pandigital Super Nova Screen Replacement: adım 4, 1 resimden 1.
    • Remove the three .11 mm screws that hold the battery in place.
    • Set aside.
  5. Pandigital Super Nova Screen Replacement: adım 5, 2 resimden 1. Pandigital Super Nova Screen Replacement: adım 5, 2 resimden 2.
    • Unplug the battery and remove from device.
    • Avoid touching the motherboard as it is fragile.
  6. Pandigital Super Nova Screen Replacement, Front Facing Camera: adım 6, 2 resimden 1. Pandigital Super Nova Screen Replacement, Front Facing Camera: adım 6, 2 resimden 2.
    • Use a metal pry tool to separate the camera and the small clip that holds it in place.
    • Do NOT touch the MotherBoard with your bare hands. There is risk of short circuiting the device. Use nitrile gloves to prevent this.
  7. Pandigital Super Nova Screen Replacement: adım 7, 2 resimden 1. Pandigital Super Nova Screen Replacement: adım 7, 2 resimden 2.
    • Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
  8. Pandigital Super Nova Screen Replacement, Screen: adım 8, 2 resimden 1. Pandigital Super Nova Screen Replacement, Screen: adım 8, 2 resimden 2.
    • Use a screwdriver to remove the six .15 mm screws that hold the motherboard in place. Set aside.
  9. Pandigital Super Nova Screen Replacement: adım 9, 3 resimden 1. Pandigital Super Nova Screen Replacement: adım 9, 3 resimden 2. Pandigital Super Nova Screen Replacement: adım 9, 3 resimden 3.
    • Remove the eleven screws that hold the screen to the base. Eight are .15 mm and three are .11 mm.
  10. Pandigital Super Nova Screen Replacement: adım 10, 2 resimden 1. Pandigital Super Nova Screen Replacement: adım 10, 2 resimden 2.
    • Remove the motherboard from the tablet using a nylon spudger.
    • A regular black nylon spudger should be used to avoid damaging the motherboard.
  11. Pandigital Super Nova Screen Replacement: adım 11, 2 resimden 1. Pandigital Super Nova Screen Replacement: adım 11, 2 resimden 2.
    • Use tweezers to carefully remove the connector between the screen to the tablet.
  12. Pandigital Super Nova Screen Replacement: adım 12, 2 resimden 1. Pandigital Super Nova Screen Replacement: adım 12, 2 resimden 2.
    • Use a pry tool to carefully separate the motherboard from the hard casing.
    • Excessive force in this step can damage your device.
  13. Pandigital Super Nova Screen Replacement: adım 13, 1 resimden 1.
    • Lift the motherboard out of the tablet.
    • Remove the second connector between the screen and the motherboard.
  14. Pandigital Super Nova Screen Replacement: adım 14, 3 resimden 1. Pandigital Super Nova Screen Replacement: adım 14, 3 resimden 2. Pandigital Super Nova Screen Replacement: adım 14, 3 resimden 3.
    • Pry the silver screen box from away from the device.
    • Open each of the four clips securing the screen box to open it.
  15. Pandigital Super Nova Screen Replacement: adım 15, 2 resimden 1. Pandigital Super Nova Screen Replacement: adım 15, 2 resimden 2.
    • Lift the screen out of its protective box.
    • If the protective box is damaged, it will also need replacing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
sterling hannsz
267 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 1-2, Bennett Fall 2016 Texas Tech, Team 1-2, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 253
