Neye ihtiyacın var
With the phone face down on a hard surface, locate the six 3.5mm Phillips screws around the perimeter of the phone.
Use a Phillips #00 or #000 screwdriver to remove all six Phillips screws.
Slide a Plastic Opening Tool in between the front bezel and the back case, slowly working it around the tight edges.
Starting at the charging port cover open by prying away from front face to remove back case.
After removing the bevel and back case of the phone, you will now see the motherboard and other internal components.
After removal of front bezel and back cover, locate and remove two Phillips #000 screws from the top corners of the phone.
After taking out the screws, lift off the black plastic piece containing the speaker, Micro SD card slot and SIM card slot.
