Ana içeriğe geç
Pantech Breakout Back Case Replacement
Neye ihtiyacın var
    1. Pantech Breakout Back Case Replacement, Remove Screws: adım 1, 1 resimden 1.
      • With the phone face down on a hard surface, locate the six 3.5mm Phillips screws around the perimeter of the phone.
      • Three of these screws are black, while three are silver.
      • Use a Phillips #00 or #000 screwdriver to remove all six Phillips screws.
      • Righty Tighty, Lefty Loosey!
      FixBot'a Sor
      Yorum Ekle
    2. Pantech Breakout Back Case Replacement, Separating the Back Case: adım 2, 2 resimden 1. Pantech Breakout Back Case Replacement, Separating the Back Case: adım 2, 2 resimden 2.
      • Be careful when prying the plastic bezel and back case apart from each other; the parts are connected by both snaps and adhesive. Forcing the back case off could result in it breaking or cracking.
      • Slide a Plastic Opening Tool in between the front bezel and the back case, slowly working it around the tight edges.
      • Be patient, it may take several tries to remove the bezel and back case successfully. You may need to slide repeatedly along the edges of the entire phone perimeter to loosen the adhesive between the two pieces.
      FixBot'a Sor
      Yorum Ekle
    3. Pantech Breakout Back Case Replacement, Removing Back Case: adım 3, 2 resimden 1. Pantech Breakout Back Case Replacement, Removing Back Case: adım 3, 2 resimden 2.
      • Starting at the charging port cover open by prying away from front face to remove back case.
      • Make sure that no part of the back case is caught on any other part of the phone; the USB charging port can get in the way.
      • After removing the bevel and back case of the phone, you will now see the motherboard and other internal components.
      FixBot'a Sor
      Yorum Ekle
    4. Pantech Breakout Back Case Replacement, Component Board Separation: adım 4, 3 resimden 1. Pantech Breakout Back Case Replacement, Component Board Separation: adım 4, 3 resimden 2. Pantech Breakout Back Case Replacement, Component Board Separation: adım 4, 3 resimden 3.
      • After removal of front bezel and back cover, locate and remove two Phillips #000 screws from the top corners of the phone.
      • After taking out the screws, lift off the black plastic piece containing the speaker, Micro SD card slot and SIM card slot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ryan Murphy
898 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Mcgee Fall 2014 USF Tampa, Team 5-5, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G5
4 Üyeler
84 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 699
