Ana içeriğe geç
Pantech Breakout Battery Replacement
Neye ihtiyacın var
  1. Pantech Breakout Battery Replacement, Removing Back Cover: adım 1, 3 resimden 1. Pantech Breakout Battery Replacement, Removing Back Cover: adım 1, 3 resimden 2. Pantech Breakout Battery Replacement, Removing Back Cover: adım 1, 3 resimden 3.
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Pantech Breakout Battery Replacement, Removing the Battery: adım 2, 2 resimden 1. Pantech Breakout Battery Replacement, Removing the Battery: adım 2, 2 resimden 2.
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Murphy
898 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Mcgee Fall 2014 USF Tampa, Team 5-5, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G5
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 2,224
